200 Series tech and classifieds.
Compress high side with KDSS open. Close KDSS valve. Decompress. Profit.
I'm telling you, that method works. I've done it myself.
Better yet, just pull the PS rear coil and install a 10mm 80 Series OME trim packer. Very easy, and will def help the lean.
Done. It's perfect for a Highlander
Whatever they did fixed it.
What the invoice says is rebuilt PS coil over. It was not even with DS which is why it was leaning. Reset KDSS tightened some loose bolts on the UCA and repaired the speed sensor that was loose. Get stock fittings on rear sway bar that was kind of rigged since parts were unavailable earlier. Main thing was coil over and KDSS.
Had other routine maint done while there.
Bought an ARB awning while there.
I will spend the next year adding stuff. They have a baja rack i like so thats next.
I think I've got a loose speed sensor too. What were your symptoms @MEMCruiser ?
Rigged up my awning. I see why Bomar went in a different direction. Those things are kind of a PIA.
What model is it and how much would you Cell it fore?
