Few shots of me on tour
Do you ever find yourself occasionally unable to resist shooting photos of your LC—even just sitting in your driveway? Or am I just looney?
Is that the all electric Toyota 200 Series?
Why did you need the extra cooling fans on your turbo cooler?Hello from Peru. My lc200, diesel.
the explanation:Why did you need the extra cooling fans on your turbo cooler?
Finally mounted the rear camera in the spare center cap. Looks great at 20'. I need to re-sand and re-paint, as this was a rush job. I was tired of no camera. My back up sensors detect the tire and latch, so I turned them off.
It's only 4 wires @Markuson, I used direct burial sprinkler cable.
Stock camera, stock mount. Screw tabs cut off of mount. Center cap cut out. Mount epoxyed to inside of cap. Camera reinstalled 180° from stock. Epoxy putty used to smooth out everything (I need to re-sand and re-paint).Nicely done.
Is that the stock camera?
If so, where did you source an extension?
Smart man with the disconnect.Wirh the little pig tail, I can remove the spare and disconnect .
Yes! Planning it all out, that was the biggest gotcha.Smart man with the disconnect.
