200 series jack adapter
Mine showedup today, wow this is nicer than I expected. I assume these get tossed into a tumbler after welding to get rid of the sharp edges?
Now I hafta figure out the best way to stash it in the cubby so it won't rattle or move around.
Close, parts are cut, tumbled then welded. Our new builder does nice work why I reordered when I picked up this run.
Behind the factory jack facing forward works in most cruisers.
Several guys have asked about Jack Adapters for a hyd. jack. I do have Jack Adapters to fit hyd jacks but there is a problem is why I dont list them. Most hyd jacks will not fit under the axle when you have a flat. This is the problem with Safe Jack it will not fit under your axle when flat. The factory jack is an excellent jack and will change any tire you can fit on your cruiser in addition to work ever time and in any position.
Safe Jack next to a factory jack wit a flat
I just got mine. It stores nicely in the cup inside the door to the jack storage nook.
