1st Land Cruiser
Well neither locked carrier I bought has the slots for the c clips so I can't use them in my rear axle. That's kind of a downer.
I think my problem is that I cannot get the cross pin out because the 4.88 ring gear is so thick. If I can get the cross pin out I can do it. Just used to a Dana axle LockRight that has the slots for the c clip.
Yeah I need to get the cross pin out past the larger 4.88 ring gear
I think I know how I just have to get something to pop out the springs. Then the pin should come out.
Looks like I need to clearence the ring gear to get the pin out. I am guessing the guy I got it from didn't have a c clip axle so it was setup all on the bench
Yeah I looked at that. I need to get the pin out by clearencing the ring gear.
Just the rear one needs to have the ring gear ground a tad to get the pin in/out. Check them both to make sure one isn't already done. If the PO had a full floater rear he would not have had a need to do this.
Yeah I checked them several times to make sure and neither are ground. Also the slots are not lined up making me think he had a full floater.
