I have done a manual pump (hybrid 2LT and 1KZTE) here is NZ.
For the Tacho I used a kit from Jaycar....
Speedo Corrector MkII Kit "Kit Back Catalogue" - Jaycar Electronics
As the sensor in the 2LT pump was different to the 1KZTE.....
I still have the factory ECU which now just drives the Glow plugs....
Also I run the auto and manualised it....
Here is a link to what I have done.
A340 Auto manualising completed | New Zealand 4wd Forums Offroad Express
I tried to have the auto run like factory keeping the TPS sensor but it didn't like it and was very slow to up change gears at hi-way speeds....
So went the manual way... Works great and didn't need to buy some expensive aftermarket controller.
Just need to flick a switch for torque converter lock up....
But its a play truck now not a daily driver so not an issue.
For setting my timing I used the 1KZT setting but it was too advanced, pulled really well but was very noisy, sounded like a petrol motor pinking...
I just set it by ear, backed off the timing until it sounded smooth at idle (when hot)...
Took it for a drive.. And adjusted a little bit more advance so it didn't get the horrible pinking...
Seems to run fine....But still tweaking.. Playing with boost compensator next..
The aftermarket transmission controller you mentioned, do you have a part number or link? I really want to keep the auto tranny functioning as this is my daily driver. KZJ95 Prado with the 1KZ-Te.AND, it's already been brought up in an email, so I figure I'll post my thinking on the subject here.
To avoid having to machine the mounting slots, I came up with the idea of just moving the timing gear in the case to get the offset I needed to put the pump in the ballpark. Thing is, the camshaft is driven by a timing belt that is driven by the pump timing gear. Any offset to that gear would also offset the timing belt and cam. The timing belt pulleys are both odd-numbered, and unless the timing gear had a multiple of that number of teeth, I wouldn't be able to offset the timing belt by a tooth. That, plus the fact that I'd have to open the timing case (something I wanted to avoid if at all possible), resulted in me just slotting the holes beyond stock.
So far you guys are pretty much caught up on my progress. If you have any questions, let me know. I'll definitely be keeping this thread updated as I sort out the other small issues.. but so far I'm convinced this is a great option for the 1KZ-TE engine. For anyone considering a 1KZ-TE swap, it should be noted that you can buy the pump and throttle linkage for around the amount of money you'd get for a good used 1KZ-TE pump and ECU.. resulting in a mechanical pump 1KZ. That would require ditching the automatic, or using an aftermarket transmission controller (these are commonly used by Supra guys). That makes the whole swap far more attractive from my perspective.
-Justin
Do you have the details on how you did the hybrid of the 2LT and the 1ZK-Te pumps? and will the Auto tranny still function from the factory ecu?
Hi EveryoneHello all,
4M40 is a 2.8 liter mitsubishi turbodiesel engine, with a factory intercooler. It is indirect injected, also with 150kpa opening pressure. It uses a Zexel mechanical injection pump, with boost compensator.
No. I just made the mounting post slots bigger so I could tilt the pump further.hello. sorry for necro-ing this post. i need some clarification on this quote. Did he move one tooth on the injection pump gear?
It has been too long since I did all this to remember, sorry. Note what I said about turning the gear moving the timing belt pulley though.Is it possible if i just move one tooth infront of the pump gear? I talked to a guy he said he moved a tooth.
Please replyHey bloc great write up mate I'm wanting to do this myself but wnat to know about the term turn out. How many ks have you done and have you had any issues with the motor due to timing?
