Hi all,
yes I am a newbee,
I have a 1hz engine in my 1995 troopy. its a hzj75rv .. I purchases 2nd hand ex queensland rail when it had 56,000km..on it.. When I got it , I took to percys auto in rocky ..who did all the engine works for Opposite Lock 4wd...I paid about $3k back then and fitted a non intercooled turbo. I fitted a schwitzer 311301...My 1hz has now done just under 500000km...When I had the turbo fitted the pump and injectors got serviced...I believe the setting for mine is 10psi. It gets 14-15litre on a heavy load...and 11--11.5l empty load on the highway..the turbo only needed a replacement t In the vac line...The engine ...had valve sims done 2 times..replaced timing belt every 90K...all original...
When doing some real heavy continuous work...like dragging 3.5 tones from WA to QLD....given I had no rad shroud due to kangaroo smashing it so bad I had to remove it...I had a little overheat with load (which was 10ft from ground and 7ft wide) wind temp (40c plus...)...note my current rad number 2 is 4 core not a 2 core..I had to do so many water cool offs and top offs.
this brought me to realize ..more and better cooling was needed...
mind you my car empty with the shround back.,..can go cold ..if not being hammered...based upon outside temps..
now I wanting to upgrade things to get better proformances when I tow longer distances now..
and first one I thinking of doing is snorkel...I got it and just need to fit it..
second upgrade is I got a oil filter adapter and oil cooler rad with fan...and I plan on installing the oil rad...onto the bottom protector skid plate..cutting a slit to have air come in and having the man switch for fan fitted to it..
third ....I thinking about placing a vent in the bonnet over the turbo...to direct cool air over the turbo...and maybe placing a small 12v fan over the turbo as well....
* this will be my form of intercooling *
Now I know my engine and turbo are getting long in the tooth....and I dought I can get replacement parts for current turbo..
So
I am thinking engine upgrade...
I have a spare 1hz non turbo engine ..with 300000km on it sitting on a pallet....it was my ..just in case ...(backup)
since I prob have to dump the brilliant turbo I have ...due to parts supply issues..
I am thinking about should I stay with 1hz engine base or go 1hdt..
could I mungrol the spare to a 1hdt...and should I
could I do that cheap...since I wanting to rebuilt an engine to fit...so the on ground spare ...could be made a 1hdt or swapped for rebuilt 1hdt......I want to keep costs down..
I am wanting a little more power and hold on or improve my consumption...by going from non direct to direct and going non turbo injectors to turbo injectors..
I like the easy no brainer swap out as well..
Can anyone offer a little here to help me make informed decisions
thanks
phil
yes I am a newbee,
So
thanks
phil
