1HZ injector servicing
Brisbane Australia
Just got a couple of questions.
How often do the injectors need cleaning or replacing normally?
I had them cleaned at 50000k as I had a bit of a problem with one. I have now done about 260000k. It is still running ok and no obviuse problems other than noticing a little lacking when towing the boat.
How often do most do the valve clearances?
How often to do the front axle seals and swivel housing rebuild?
REbuild swivel houseing when it breaks - however clean and regrease all wheel bearings every 40,000k, can do the axle seals at the same time while its all apart. I used to use castrol marine grease one tub per wheel..
Injectors recommend every 100,000 as a maximum.
THis all came from my 80 are you runnign a 75 proablby same service intervals anyway.
