1HZ idiot light temp sensor/sender?
Metro NY
Does this exist from Toyota? Direct fit aftermarket?
If so what temp is it set at?
I was asking if there is a 1HZ model truck that has an idiot light rather than a gauge.
Yes, I am adding a "good" aftermarket gauge. I am wondering if there is an OEM sender for an idiot light that would work in the 1HZ
Have you thought about just using the temp sender on the LH side of the cylinder head?
(See, now you are just messing with a 1HZ newbie...)
No, I haven't thought about it because I didn't know it existed. I'm trying to absorb knowledge now to minimize randomly flailing around under the hood later.. so thank you!
Please: is that an on/off sender rather than one that sends variable voltage to a gauge? If so, do you know what trigger temp it is set for? What is is used for in stock form?
(see pics below)
Coolant Plug
Oil pressure sender
Coolant temp sensor
Do I have those three right?
