1HZ H55F combo
Greendale B.C Canada
JDM 1HZ H55F combo $6800
Standard G&S servicing done valve clearances set, compression, oil pressure tests done
ACL big end con rod bearings so it's Turbo ready
New Denso injectors
Rebuilt Injector pump, all Denso parts
C/W HZJ73 intake can and #1 air hose
C/W Used HZJ73 rad
No starter, no Alternator, No AC compressor
Extra $200 for the test bed for all mounts etc, it's the front half of an HZJ73 frame on castors.
Pick up only
Located in Abbotsford B.C
Right on US border north of Seattle.
12v/ 24v (sorry if this is a dumb question)
does it have the brackets for the A/C and alternator?
also $6800 canadian or US$$
thanks
clint
If you are picking up it's Canadian Dollars ($5800ish USD at todays rate)
Glow plugs and fuel solenoid are 24volt.
Yes on the Alternator bracket, FZJ80 alt is a bolt up.
No on the AC bracket/tensioner.
I dug up an AC compressor bracket for it if that helps. No idler/tensioner though.
Can we slam it in the 80 this afternoon? Or put wheels on the test frame and hitch me up? Nope, I gotta head south. Darn, Bob
For sure dude!
Sold.....
