I know these engines make some ticking noises pretty much normally. Mine, however, has been steadily getting louder over the past few months. On idle, it sounds fine. Rev it up and it sounds fine. While driving there is a fairly loud ticking under very mild acceleration, or coasting. It sounds like it is coming from the RH side but I cannot tell for sure. Did I mention that at idle the sound is gone? Very difficult to diagnose when the sound only occurs while driving. The sounds is kind of metallic, but not overly alarming. Kind of sounds like fingernails tapping an aluminum can.
More information: the sound only manifests itself after the engine is warm. This leads me to believe that it may possibly be ACSD related - even though that's on the LH side.
History: oil level is good - been running 15W40 Rotella T. Only using genuine Toyota oil filters. BEBs were replaced this summer. The sound was there before the replacement, and did not get worse immediately after replacement. I have a very small bit of oil weeping down the LH side of the block. But oil level never drops on the dipstick. The PO removed the stock air cleaner and fitted a cone K&N. I've just cleaned and re-oiled this.
I have not checked the valve clearances yet. I've been enquiring about where to get shims before I pull the valve cover. But the sound was basically not there last winter.
So, ACSD? Valves? Or something else? Truck runs beautifully despite the sound - a bit smokey (gray and black) but has plenty of power. The ticking is ruining my driving enjoyment though.
