Hi! I would like to know if anyone encountered making there 1hdt intercooled? because my LC80 1hdt decreases power since i installed intercooler. engines pick up is more delayed. any suggestion what to do?
You have to do ab bit more than just bolt on an intecooler kit.
Mine was installed while the truck was on a chassis dyno. They did a before run and then fitted the kit. It was a Safari intercooler kit. Then they did a run after fitting but before adjusting the fuel. bugger all improvement.
Adjusting the fuel until it was at the maximum produced good results. removing the fuel adjusting bolt and removing the nut that was swaged on there by the facotory to allow even more adjustment got even better results.
Dialed the fuel back to a useable position ie: a balance of exhaust soot and horses at the rear wheels.
I was well happy with the result. As best I can remember my truck JDM HDJ81 went from 70kw at the rear wheels to the mid 90s. Could have more but would / should have an exhaust pyro for safety.
Turbo lag is already pretty bad with the big turbo. The additional volume of the intercooler plumbing makes it worse. Re- tune as prevoiusly prescribed above but be ready for a corresponding rise in fuel consumption to go with the power increase.
Post up some pictures of your intercooler and piping. I'm wanting to do the same after my water/meth injection install. Do you have a pyro and boost guage? From what I understand you can turn up the boost 2 or 3 psi to make up for the lag and enjoy some lower egts and better economy or turn up the fuel to enjoy increased power. A pyro and boost guage is a must. It doesn't take much fuel adjustment to get lots of power and extremely hot egts.
You might get a few more views in the diesel section.
my intercooler is the safari intercooler bolt on kit. any idea of the consumption if i dyno tuned my LC80?
right now its very fuel efficient but im encountering a delay on torque when i installed the intercooler. its more slower than before without intercooler.
Turbo lag...install a pyrometer and boost gauge as previously mentioned and play with your boost and fuel settings until you have it where you want it in terms of performance.
On my setup, I'm not planning on going past 10-12 psi max, so it wasn't worth it for me to mess around with trying to figure out an intercooler system.
