I have a 92 1hdt and the 2 belts on the alternator to the water pump and of the harmonic balancer keep coming off I have re machined the alt bracket and new belts every time they come off any help would be fantastic
Check your harmonic balancer. The rubber is known to seperate and if you dont catch it early enough it will damage the crank.
You know this is a diesel right?Download the FSM, it has the specifications and how to test belt tension. You can use any decent belt tension tool to measure it. There is a good thread here Adjusting belt tension on an 80 - good tool
Diesel? whats that?
OP Please check the balancer regardless... If it is separated/ imbalanced it will get very expensive in a hurry...
It wallows out the keyway on the crank. No impact on engine idle.please explain to the novices here (me for example) what can happen when/if the balancer is ruined? what will get damaged and how? I have a very boring and rough idle, like its skipping. new IP and redone injectors.... (1HD-T in a HDJ80 1993) can the balancer screw up the idle? (sorry a bout the thread hijack)
