dame-it. I need to start saving for a turbo.
Oh ya - and an intercooler - your truck will run hot egt wise without an intercooler.
why would it run hot?
If the turbo is working within its efficiency range, and fuel is tuned to suit, why would it run high EGTs?
thats true. I really want to do the combo but that is 6 grand I am out.
24v converter
Denco Intercooler, Denco Turbo kit, 3in Stainless exhaust and Isspro Gauges.
Dame my truck would be a rocket!
Because it is a 1HZ with a turbo and no intercooler in an HZJ77. Yes if he runs 6-8 pounds the egt's will be fairly low and he will run them up if he is in the big hills out west, but anything over 8 pounds and the egt's will be high if he likes the pedal and is in the hills or bucking a headwind for sure. It's the nature of the beast and it's the consensus among most boosted 1HZ owners. Add a trailer and forget anything over 100kms/hr egt wise. I forget how big his tires are but 35 inch and up are real power robbers and stock gearing will cause high egt's on the road if he is working.
All that being said if he just toots around at 90 kms/hr and pokes here and there and never revs over 2500 etc etc then no intercooler required. Start adding tires, gears, loads, hills, trailers, headwinds, hot temps, type of turbo, etc etc and better start adding boost and mods ie intercooler, ceramic coating, boost comp to keep the smoke down.
Lots of factors, but to just say a turbo in the efficiency range limits the application.
Louis
Wait before you get a denco kit, I'm trying a bigger intercooler and suspect it will work better. I also think there are better options for turbos, but yes on the 3 inch exhaust, ceramic coatings etc. If you do everything yourself then you can do it alot cheaper than 6K.
PS, you know what makes a big difference on egt's???? Correct valve shim adjustmentI just set mine and a very big difference in power and egt's, bonus!
Do you have an intercooler setup on it?
Below are the coolers I make for the 1HZ-1HDT.
Cool.
Are you going to get that intercooler from aus or stick with the frozen boost?
What did your turbo set up run you in the end?
Sounds very cool! What's the max egts you try to limit yourself to? What are your thoughts on longevity?
How much boost are you running Tim? 21 pounds like your profile says and still no intercooler?
Thanks.
Louis
