hey everyone, I have a 1993 1HD-T with a manual transmission. I’m having an issue where when I go up hills, and break at the same time, my engine will stall out when pulling up to a stoplight. It also has the same problem when making a sharp left turn, bogs out with no acceleration even with the pedal to the floor (seems no fuel). it has also been harder and harder to start it (used to start right up but takes 3-5 seconds of cranking now). in the situations where it stalls, it takes 10 seconds of cranking to get it started again.
only thing i can assume is some internal springs are worn and ready for replacement. engine has 575,000km on it so no surprise there, not sure of previous rebuilds. i’ve done extensive searching and reading through old threads on this topic as it seems to have been a problem before, but no real final solution ever comes up. so my questions for the group:
should i just move forward with a rebuild of the pump and injectors? looking at making more power in the future, so could upgrade the pump at the same time.
any reliable shops that can rebuild a denso pump and injectors here in the US? looked at the shop in Oregon that has been mentioned on here, but the have a 3-4 week turn around time; which means i’m 5-6 weeks of downtime on my daily driver.
i’m also looking for exchange options so i can minimize downtime but everyone seems to be out of stock.
pump info:
pump info:
- Toyota PN: 22100-17540
- Denso code: 754
