Might be time to take it for a long drive down a short boat ramp :'(
Yes the nozzles were scored so had to be replaced.
I've been through a lot with this truck and could buy a new 200 VX for what it's cost me in 10 years but this year has been hard to swallow. Spent $13k and barely a trouble free mile in it.
I know you said your engine mounts were replaced, but that's a LOT of movement for good mounts to allow IMO.
Did injector lines get replaced?
If you got shrapnel in injector nozzles, maybe you have partially blocked injector lines?
No. Original lines used. I was away at work and didn't do the pump refit. I didn't think of the lines being obscured, but this makes some sense.
The shake really is like an engine starving for fuel. But why only when it's hot!? This part doesn't make sense to me.
Do you think I could try clearing them with compressed air?
What would the ID of the lines be?
Something is expanding and losing pressure. IP do this but normally after they are well warmed and usually at higher speeds. It is usually the first sign of a worn out pump.
What happens if you bump the idling up 100rpm permanently?
