For Sale 1HD-FT EGR blockoff plates - $50/set
Thank you @kenavt
I have received my order for the block off plates for my 1HDFT.
I was going to try the bypass vacuum lines first...but I have soaked the bolts and nutes in PB blaster.
I tried cracking the nuts and the top 12mm cracked easy (loosen).
The bottom two 14mm one started to slip a little. I soaked it some more. Went to toghten slightly, then back off (loosen), then they came off.
At first, it was so hard to get the EGR removed, then saw that I forgot the support bolt at the bottom. (After I had been prying at the top two on the intake side). After I got the support bolt out, I was able to remove the EGR easily.
Thanks again! Beautiful product.
I got the plates installed and took it for a test drive. Works good!
Thank you for the notes for others and the nice remarks! PB Blaster is definitely useful on a lot of our rigs, and there are a lot of bolts that are easy to miss!
I've designed some EGR blockoff plates for 1HD-FTs that folks can use for removing their EGR systems before they soot up their lovely JDM imports. I've written up instructions in this thread.
A set comes with laser-cut aluminum blockoff plates for the intake pipe, and laser-cut stainless steel for the exhaust.
I'll sell them at $50/set; delivery in <2 weeks. If you're interested, please DM me with an address and Paypal or Venmo address. If I get a lot of interest and people are flexible around shipping times, I could potentially do a larger group buy to bring down the cost - please also DM or post in this thread if you're interested in this option. I'm not really sure how much demand is out there!
Any available? Would love to get this job done
Yep they’re still available! Please DM me with address/payment info. It’ll be a bit delayed as I’m traveling at the moment.
Interested in a set if you're still making them, unable to PM you, account is too new I suppose.. (New HDJ81 owner)
Looks like I can send you a DM! Sent you one.
