1FZ Valve Adjustment
Indiana
Question for the 1FZ gurus: after 5K miles on a new short block with rebuilt head, does it seem normal to require a valve adjustment? Or would this be the fault of the machine shop that did not get valves adjusted properly when head work was done? My independent shop (not a Cruiser shop ‘cuz there ain’t any where I live) is recommending a valve a adjustment at 5K miles after the motor work they did for me.
It would be prudent to check!
I hope the shop, if valves and seats were ground, assembled the cams to the head and if necessary (more than likely) tipped the valves so you were in the middle of the shim adjustment band!
Most shops that do the machining, do not do valve adjustments. They usually state it's the responsibility of the installer to do it and check.
Source, I am an installer and never received heads "adjusted and ready to go".
