1FZ Fuel Pressure Testing
Oklahoma
Hello fellow mudders!
I am curious if anyone has done fuel pressure testing on their 1FZ. I believe I may have a leaky injector, bad fuel regulator, weak fuel pump, or clogged filter. My 94’ 1FZ has lost power intermittently over the past month while the truck is under load, all at different speeds. I believe I have this issue down to a fuel problem. After reading some other threads, I am still unsure how exactly to test my fuel pressure due to their not being a schrader valve preconnected to the fuel line/rail anywhere. Any tips/pictures would be greatly appreciated.
I would also like to state that while testing my OBD1, the voltage on my oxygen sensors are great, jumping between 0.1-0.9. While testing my VF1/VF2 to E1, the voltage is 0.08v and 1.12v. Very low, after reading my ECU is adding extra fuel to the fuel/air mix. Could this be in correlation a potential problem listed above? Could replacing any of the things listed above solve the power cut out as well as the ECU needing to add extra fuel?
There are some solutions for a pressure adapter/banjo fitting at the back of the fuel rail or another vaporware solution off the pressure regulator connection if you search the forum.
In the mean time I would hookup a wire from the FP terminal in the engine bay diagnostic connector running into the cab hooked to a volt meter and monitor the voltage going to the fuel pump. By design, the system operates under two voltages, controlled by the ECM. Monitor voltage to see if there is any correlation with the symptoms when they occur.
Used a voltmeter between FP and E1, during startup the volts measured 12v, then, during idle it sat around 9.2v. Seems to have the correct voltage. I am unable to drive the vehicle and view FP voltage at the same time so I assume that under high load, the voltage should increase to about 12-14v. FP voltage seems fine. How else can I compare the voltage to test the other potential problems listed?
I thought @cruisermatt was selling them. That was going to be my suggestion as well. Guess you could do the fuel pressure gauge hooked up and duct taped across your fender and hood method. :)
'94 FZJ80 here too.
Just went through this with our rig. Loss of power when applying gas to enter traffic, and when climbing hills.
It ended up being the fuel pump.... and it crapped out just after we rolled into camp for a wheeling weekend.
Jumper your fuel pump and turn on the key... if you hear the pump spooling up, it's "likely" not the pump... but, I say "likely" because the failed pump made all of the right noises, but it wasn't in fact pumping anything at all.
While you've got your OBD1 jumpered, pull the hose from the fuel pressure regulator. Then crank you engine... if no fuel appears, your pump is probably toast. No fuel came out of mine... except for a measly little drop. Loosened the banjo bolt at the rear of the fuel filter... cranked the engine... nothing.
Also, check all fusible links, fuses and all fuel related relays.
'94 FZJ80 here too.
I will check this tomorrow! When this happened to you, did you lose power intermittently or did it totally crap out on you instantly? I only ask because mine will have no problem revving to 5k rpm when in park and most of the time while driving too. It’s pretty random when it decides to cut out, I’ve noticed it a couple times on gradual hills.
This came on quickly. I never had the chance to see if it would rev up when I’m either in P or N… happened while driving and then… crank and no start.
I have one tester adapter left of the batch I made, I will make more and one day get them on my webstore, I am currently understaffed right now though and not trying to add too much more to my plate too soon, I was a bit pre-emptive with the thread I made but I was excited to show the 1FZ peeple
