1FZ-F vs. 1FZ-FE compatibility
Cheers guys
Tank I'm out on a small island near Australia so postage will likely be cost prohibitive. good to know that these bits are still out there though
FE having a block off plate where the fuel pump mounts on an F. Manifolds interchange, as does everything else.
Wait, the HEADS are different, correct? One can't simply bolt the EFI intake manifolds to the -F head, yeah?
Also, let's assume one goes from -F to a -FE conversion. How picky is the ECU in needing EGR, O2, transmission input, &c &c?
All I can say is on the 2f/3fe one difference between the heads is an opening in the intake ports for the fuel injectors. With verifying for the fz
