1FZ cannot jump TE1-E1 and set base timing
Northern New Mexico
1997 coming off of a HG job and troubleshooting rough idle when warm. I even bought the fancy tool from HuddExpo and no matter what I do I can't get the check engine light to flash when ignition is ON, and timing doesn't change. Currently shows past 15 BTDC. The diagnostic port doesn't appear corroded or damaged and I can't find any other possible solutions.
Does your port have dialectic grease in it?
If it does, the grease doesn't conduct electricity. I've had trouble getting a connection a few times because of the grease
No it's bone dry.
Obligatory dumb question but does your cel work?
It illuminates when ignition is ON. Are there further diagnostics I can do?
Are you absolutely sure you are jumping the correct pins?
It seems pretty idiot proof but I'll have another look! The terminals are pretty loose but I've tried different thicknesses of conductive materials to get a good connection.
I'm assuming the engine has a distributor if so, has it been replaced with an after market rebuild? After markets don't display codes.
I’m curious what you mean by this, would an aftermarket distributor not be sending the same signals to ECU?
Just off fresh head gasket. Double check the TDC of the distributor.
@VPP is referring to some models outside the US have individual coils so the set up is different.
I'm not sure I follow. If I was 180 deg off TDC the engine wouldn't run right? And even if I was a tooth off wouldn't I still be able to jump the terminals?
I had this issue and was unable to get mine to go into service mode, and it was due to the idle switch input.. my mechanic showed me this screenshot from his diagnostic tool:
I don't know exactly what he did to fix it, but as soon as it did, it went into service mode jumping the pins.
The 'rough idle when warm' comment, when cold, initial start does it appear to be fine / better / smoother and then once warm exhibit rough running?
this could be a coolant temp sensor faulty or connection not right meaning its effectively running a cold start enriched mixture once warm which will cause a rough idle. Check the connections of the coolant sensor
easy to backprobe and test the coolant temp sensor as well with a multimeter.. the process is in the FSM
Is that the sensor next to the knock sensor on the driver's side head?
It runs smooth when cold but has irregular stumbles when idling after warm. No CEL and it drives fine. I hesitate to even call it a rough idle because it doesn't consistently stumble.
Well now you've got me intrigued, but it sounds like you don't have anymore info 😔
I'm just surprised to hear nobody else on this vast forum has had this issue!
yes, under the intake manifold on the driver’s side at the front of the cylinder head (2 pin connector)
irregular stumbles when warm - check for vacuum leaks
- pay attention to the vacuum lines under the intake for the VSV
- throttle body plate seating properly & nice n clean
- rubber tube going from air cleaner to throttle body - check it for proper sealing & no cracks
