Wanted 1F Head
Status
Not open for further replies.
Apex, NC
Looking for a good used head for a 1F engine out of a 1974 FJ-40. I'm currently having it rebuilt but my machinist says the existing head is leaking. Any leads in the greater mid-Atlantic states would be greatly appreciated as well.
I saw you responded to my post with a head. Is your 74 an F or an “F.5”? If it’s the newer F.5, my heads will not work.
/this\
Oil filter on left side or right side?
It's on the right, what does that make it?
I believe that’s an F.5, meaning neither of my heads will work.
If you can give a needed casting number i can check what I have. logistics might be better too that I'm in Michigan.
Do you know where I can find a chart that gives the dates for different casting numbers? Amayama only has part numbers listed for loaded headed and nothing for just the head itself. Would made it easier than having find the date code which is not as easy.
I found this after doing a quick search on the forums.
Not the entire answer, but a start.
Jim
Just want to say thanks to fjc-man for saving the day! The head looks amazing and the transaction went very smoothly with great communication. Would do business again in a heartbeat! Thanks again!!
Status
