Hey Guys,
The alternator on my 1999 LX470 is going out. It started to whine a couple weeks ago and now the voltage is slowly dropping. In researching OEM replacements, I found my year vehicle specs are for a 100 amp alternator. However, if I order a Lexus OEM replacement online, the replacement is 130 amps. Similar replacement for a 1999 Toyota OEM (online also) is for a 100 amp. I would rather upgrade to a 130 amp alternator if it won't cause any problems. Any one have recommendations or concerns?
Also, just as an FYI on Optima batteries and the possible issues with "yellow tops". I ran an Optima red top in the rig from 2001 to 2015 with no issues. The red top's physical size was a little smaller than the factory batter, which stretched the ground wire to its limit. But not a big deal. When I purchased the red top, the shop didn't have a yellow top in stock and said the red top would work just fine...and as a bonus was a little cheaper. The red top never failed me, but I decided to replace it when I found a small crack next to the positive terminal. Moving on, in October 2015, I replaced the red top with the yellow top. Battery has performed well over the last year and testing shows it is still in good condition. I found some post in the forum questioning the yellow top's compatibility with our charging systems...so I wanted to throw my "two cents" in. I have over 210K miles, so I don't think the yellow top contributed to the demise of my alternator...but I guess it is possible.
Thanks!
Thanks!
