1999 lc abs and constant beep
australia
New to cruisers got a 1999 lc, abs light has been on for months with a constant beep inside the cab when running.have had no brake issues just trying to figure out what the beep is related to if not abs and how to fix it. Really just tired of listening to a constant beep wanted to disconnect it but can’t find where to do that. TIA
My 2000 LC just started a constant high pitch beep similar to what the OP described ....and its raining so I assume this is related to ingress of water.
Did you ever identify the problem that caused your beep?
A constant beep can be indicative of a failing brake booster which can lead to catastrophic brake failure. Read the pinned thread about in on the 100 series section on here to see if your symptoms match.
