Parting Out 1999 100 series
Is your grey interior a LC or LX? I have a LX and if these parts are interchangeable i'm looking for these:
- 3rd row carpet, that tucks in under the plastic interior (not the trunk mat)
- Driver side A pillar if that's what it's called (it goes from the bottom driver side dash, up the windshield then ends right over your head, it's the piece where the grab handle screws to).
- Hatch handle trim (the plastic trim around the handle)
- If it's an LX, the passenger front scuff plate
Pm sent
I sent a pm asking about the brake booster assembly.
Any idea what you would want for it? I'm in Clovis, California
Here is what I have.
Oops!
@Cruiser Corps, not much better than mine but thank you for the pictures!
7 pin trailer wiring harness
Hi, I’m looking for a couple of the plastic door tabs that hold the door panels in place. They’re located on the side of the door panels. Looking for 3 or whatever you have. Also looking for the door panel light housing/lens for all 4 doors. If you have the front passenger outer window trim that is at the base of the window. Mine is cracking and the chrome below is showing. Looking for the plastic buttons that cover up the front door 10mm nuts as well. Looking for the rear driver’s side cigarette/storage container on the door panel. Also trim pieces for the steps on the middle row. All for tan interior. Thanks.
Do you have the plugs + wires that hook up to the back of the climate control?
The wires will need to be cut to be removed, but I do need about a foot of slack.
