Build 1997 VZJ95 Build Thread
She’s running well!!!
Added 80 series wheels (16x8 +0 offset) and some new tires…testing them out and so far no issues!
My rear LSD clutch packs gave out so had to disable LSD for now. I will be saving up for front and rear Eaton Elockers.
Full build on instagram: FullyLitLED username as well!
Hoping to find OEM GCC spec stripes to complete my restoration of this original GCC spec LHD VzJ95
Put it to work for a bit! Little bit of a workhorse!
I know this was a while ago but do you know if a 4runner 3rd gen has the same ac compressor. On Amayama it is $721 toyota oem
Hey man,
I remember searching and seeing it is the same pn for the VZJ model. You got a 5vz in yours?
Often the compressor itself will be the same unit, but the clutch/pulley assembly or the inlet/outlet port will be different. The ports are relatively simple to swap out, the clutch assembly should be too but depending on what is wrong with your original it might not be in working condition.
Very nice wheel set up. Can I ask what tire size you are running with the 80s alloy? Any lift on your truck?
Hey man I’m running Bilstein 5100s in the front with like a 1.25” lift (its a coilover). The rear I am running no lift with 265-75-16 on 80 series wheels. I am using this mostly as an expo rig so didn’t feel the need for 34s…it drives like stock right now
Thanks. Looks good. Will the back sagged low when loaded? As no lift at the back. Front wheel any rubbing at full lock?
I am asking as I run the same wheel but 265 70 16 tires. But stock suspension no lift. Wonder how I can set up suspension but don't want to go crazy lift.
I have mine loaded down with rear bumper, spare, and coolers! It sat nice!!
Sadly this is the most sideways pic I have but it shows the level pretty well loaded down!
Hi Aero,
The Dobbinson kit is good because it has a option for a diesel rig with the right springs. Its quite pricy at around 2k for the full kit.
It was a good trail ride and we saw some nice views! Its always good when the license plate is all covered!
This trail is called Delta 5! Please make sure to search it on Youtube! Its a great trail with scenic views. As always, please be nice to the locals as they are nice enough to let us use their area to explore and hang out.
Leather seats are a pain when it is hot…I had covers made out of fabric with leather sides. 2 tone colorway to match the rest of the interior. It looks decent! Full build on instagram (FullylitLED)
Small detail…tcase shift boot was also redone to match sides of the seats
Sharing some photos from the last trail, haven’t been able to post because life’s been hard since my late grandfather passed away.
