1997 OD/tranny issues
Idaho Savage
GOLD Star
Idaho
Last night I was driving along in my 97 fj80 with 120k on clock, with the shifter in D and OD button engaged. All of the sudden I realized the truck was in neutral, simply reving as I continued to roll. I then pulled over and was able to drive in L & 2 etc. then D. But if I clicked on the OD, it would rev. Other odd thing was dash showed that I was in D AND L at the same time. I drove for a mile, then hit OD and all was fine.
Thoughts? I searched and found a mix of neutral safety switch stuff and also wiring connection stories, but nothing totally matched my experience.
SOLVED with new NSS.
Bueller?
Sounds like wiring to me. Search EGR wiring issues it can cause lots of issues. Typically not trans but worth a look. Check fluid levels warm in neutral.
Check the NSS barrel connector located in close proximity to the PHH. Don’t drop the pan until you have verified the connector. These connectors are notorious for corrosion and need to be checked/serviced.
@JCruse had the same experience. He started a couple threads on it that may be worth searching but they dont all list the solution. Pretty sure his was the neutral safety switch or the park/neutral switch. FWIW i was just chasing a po758 solenoid 2 fault code that turned out to be poor connection in the park neutral switch on usps side of the trans up front by the motor.
Ok I would pull the transmission plugs they do get corrosion, lose connectivity so and clean the connection, with some Deoxit cleaner, and plug them back in, and like others said the neutral switch maybe bad, and while you are at it adjust your kick down cable too
Thank you guys. Love this community. I'll report back to you once I get a minute to give a look.
UPDATE: I started with the NSS and cleaned that connection thoroughly but no dice. Today I got to the barrel connection near the PHH but it was pristine. I cleaned and greased anyway and no dice. Still displaying multiple gears on the dash and still going into neutral or low.
It appears that when I'm in D and it it's displaying another gear (say low tonight), it'll randomly change to that other displayed gear.
Anyone have any more suggestions? I read that the NSS tells the dash what to display so is it possibly the switch, itself and not the connector?
Finally found the thread with the answer (in the What Did You Do To Your 80 thread of all places). His symptoms were identical to a T and he replaced his entire switch with total success. So I just ordered one and will update this thread accordingly.
Should take care of it. The A343F trans (especially at your low mileage) is pretty darn reliable. It's most certainly an electrical problem and sounds like you have discovered the issue.
I have 315K on mine and never a minutes trouble.
SOLVED:. Replaced the Neutral Safety Switch, adjusted it a bit and all is perfectly well with crisp shifts and proper dash display. Thanks for the help everyone, especially @jfz80 for putting me on the right track.
