I plan to run a the constant power wire directly to an aux fuse block directly wired to the battery.
^^ I assume this is for the headunit not the two Amps. I did the same and would suggest you not use the factory harness ground and create your own.
Possible things you need in addition, if I am not missing something from your post, ACC in, I don't remember which wire was ACC from the factory harness but remember on the LX the power comes from the right panel under the dash speaker were the stock amp was. The power goes from that amp to the headunit. So the connectors that a LC normally would have plugging directly in to the factory head unit are actually all the way over to the right behind that speaker. I believe I tapped ACC there and ran it over to my after market Headunit.
Since you are not using the LX amp and have already wired in your two amps, there isn't much need for use of the factory harness at all.
You didn't say which headunit but if you are using a headunit with HDMI IN and HDMI out or USB IN (also Android Auto or Apply Play), you will want to get a USB, you will want to consider something like this
https://www.amazon.com/dp/B01MG27XXC/?tag=ihco-20 to bring your HDMI/USB and AUX inputs out from the back of the headunit to a place you can reach (In my case inside my center console) This will make it easier to throw any HDMI output signal up on your headunit (from car puter, cameras that out put hdmi, or cell phone/tablet screen) much easier.
You will also find ACC from the plug in the center console where you remove the cd changer.
If i find my wiring diagram tomorrow I will post it up after I get home in the evening.
