For Sale 1997 FZJ80
Lakeland, FL
Selling 1997 Land Cruiser. Located in Florida, USA. Southern vehicle most of its life. Very good overall condition for age and mileage. 275K miles (274K now but driven occasionally until sold). Daily driver. Starts and runs extremely reliably. About $12K invested. (Selling for $7K . May consider partial trade.) Exceptionally good body. Engine and transmission are particularly good. OEM wheels and new wheel security locks.
Does not have factory lockers.
I believe I am the 4th owner per CarFax and Toyota Owners site references.
Glass and seals are all intact. Clean and dry inside. Second row seats and rear seat covers are in good shape. Needs front seat covers repaired or replaced (driver seat torn/cracked, Cabella's covers over both at present) and needs nylon gear replacement on front seats (power rails/gears grind when moved). Needs glove box hinge bar, and minor repair to third row seat release bars. Center console good. Leather arm rest cover is rough. Original dash is in terrific shape. Carpets good throughout. AC is cold and reliable. Heat works great.
Many new parts including new (2016) OEM ECV, new alternator and battery, new PS pump, new OEM PS high pressure side hose, new OEM fan clutch and matched belts, water pump and thermostat, new OEM rear brake discs and pads, new OEM valve cover gasket, new plugs, wires, distributor cap, tune-up. New OEM Driver side door lock/actuator. 4 complete sets of keys for the truck including Driver Door Keys/Ignition Keys. Original owners manual and docs on all repairs I've had done at Toyota dealer, and via local licensed mechanic (tune-ups, oil changes). Some new suspension parts (Toyota OEM tie rod/ends). Detailed review by Toyota dealer on future non-urgent needs (see below).
Toyota White with tan interior. 3 coats of high quality enamel from local paint shop (some ripples but looks fine). Rear bumper ends are crunched but serviceable. Has OEM towing harness but no OEM receiver hitch. However, 4 bolt Pintle hitch/sleeve bolts perfectly to the bumper. Front bumper good. Brush Guard removed, repainted and reinstalled when body was painted. Recent oil and lube, radiator flush, heater core flush, engine coolant flush, transmission flush and lube.
Future needs: At some point will need front axle seal on right side and eventually one or both Birfields. Seepage only. Minor engine oil seepage (not enough to drip on ground/needs oil pan gaskets and maybe eventually the front seal). Tires good with 30% tread remaining.
Per Toyota, needs ABS CPU under driver dash ($200 reman), SRS central CPU ($175 reman, under center console front). Needs front exhaust down pipe (cracked, not loud, but leaks enough to mess with the front two O2 sensors and cause a disagree light).
Have many additional photos of exterior, interior and undercarriage. Please reply if interested with an email address and I will forward.
