1997 FZJ80 no start ???
Florida
1997 FZJ80 with 223K miles. When I purchased it from the previous owner, it had a Viper alarm/remote start setup installed and was functioning correctly. Only other non factory electrical is a winch and a set of ARB Solis lights. No mystery wiring underneath or known electrical issues. The battery is a red top Optima and currently reads at 12.40volts. I replaced the fusible link and cover a few months ago. Ran fine yesterday and today when I put the key in, everything lit up on the dash as normal but when I went to start it, there was a muffled "pop" like noise and everything went dead...no electrical power at all. I'm thinking it's likely not the fusible link. My electrical knowledge is very limited so suggestions on where to start diagnosing, checking would be greatly appreciated.
I would first check for a loose battery connection
Muffled POP...that's a fuse, friend. Start with the second one down middle row in the pass compartment (10A). That's the dash fuse. If that's not blown, look at the fusable link. Doesn't matter which one is blown, you're still in for a hunt to look for the short. Look where the wires pass through bulk-heads and go around sharp corners.
Can you post up a photo of your Optima battery and the connections?
Did you have to pull/stretch the cables to get them to fit?
Here's a thread from awhile back:
Not the electron Guru but check this fuse also (engine bay fuse box):
Red 50A AM1 fuse is blown (no power)
Yellow 60A fuse (original) shows some green oxidation but is still good
And after the battery terminal clamps, that would be the very next thing to check.
There are 3 fusible links in the set. Each one feeds a separate sub-system.
Check fuses/links with a meter, not your eyeballs.
Appreciate everyone's guidance and suggestions. That being said, I have resolved the problem and it was very simple. Broke out the FSM and voltmeter and tested the battery...still good at 12.40v. Checked the fusible links...again good. Grabbed the terminals and tried to move them, nope...nice and tight. Terminals are also nice and shiny with no corrosion....hmmm, WTF ? Checked the wires attached to the negative terminal and the wing nut...snug and no corrosion. Checked the positive terminal wingnut and the wires attached to it. Wingnut tight but wires loose. Pulled wingnut off and replaced with a regular nut and tightened it down. Wires now tight to the terminal post with no movement. Put key in, turned to the on position and now I have power. Fired right up. So, to sum it all up...the issue was some Cheap Charlie ChiCom battery terminals that were installed by the previous owner . These will be getting replaced this week. Anyone have a source for quality battery terminals?
You also have the wrong battery. The Land Cruiser uses a 27F battery which has the positive post on the left rear of the battery. The battery you have has the positive on the right side near the fender. As stated in another post in the last day, the positive on the right is a potential problem that could end very badly if things get bounced around. Its even a danger installing the battery and tightening the positive without shorting it out.
With that type of battery clamp you do not want to connect wires to the tighten bolt, use the posts with the wingnut and a real bolt.
Can you elaborate why this battery is unsafe or post a link to the thread that explains your theory ?
OEMs install batteries that way for a few reasons.
1) Reducing the chance of an accidental short during an accident.
2) Reducing the chance of an accident short when using tools near the positive terminal and the body.
With that said, I did install a F style battery as a second battery on the passenger side, despite the positive terminal being closer to the fender.
I did this to allow swapping batteries from left to right.. Which was more important to me than preventing an accidental short.
