- Location
- United States
***SOLD***
1997 Toyota Land Cruiser
cylinders: 6 cylinders
drive: 4 wheel drive
fuel: gas
odometer: 147,xxx
paint color: Green Mica
title status: Clean
transmission: automatic
price: $16,000
For sale is a 1997 Toyota Land Cruiser FZJ80 – 40th Anniversary Edition with Front and Rear E-LOCKERS.
I purchased from a land cruiser shop near Ft. Lauderdale in 2014. At that time it had just over 110,000 original miles. Now it currently has just over 147,000 miles.
I added the following items:
MECHANICAL
new Magnaflow single cat w/ custom exhaust tucked between body and frame
new water pump
new Steel OEM Toyota Radiator
new Denso Alternator
new Denso AC Compressor
new Interstate battery
new o2 sensors
new EGR valve
new hoses
new plugs and wires
new Toyota belts
changed T case fluid
changed Transmission fluid
changed front and rear diff fluid
had the timing adjusted and AC serviced
Toyota OEM oil filters and Mobile 1 oil every 5K
This past Spring I rebuilt the front axles using OEM seals, bearings, felts, w/ Marlin Crawler inner seal.
ARMOR
ARB Front-Bumper
BIOR by Metal Tech Bolt on Sliders
4x4 Labs rear bumper with spare tire swing out. Custom Built from Kit.
After that addition, all of the armor was professionally rhino lined
WHEELS AND TIRES
5 New Goodyear Duratracs with 5 American Racing Outlaw II wheels
AUDIO
I added a 10 speaker Rocford Fosgate System with Rocford Marine Grade Amp and Pioneer 7” Head unit. All professionally installed.
LIFT KIT
4" SLEE lift kit - retailed for $2800
Kit Includes:
2 x SOF4FM Front Coil Springs
2 x SOF4RM Rear Coil Springs
2 x N60070L Shocks
2 x N60071L Shocks
1 x SD24 Steering Damper
1 x Slee Front Caster Plate Kit
1 x Double Cardan drive shaft.
1 x Front Sway-bar Drop Kit
1 x Rear Sway-bar Drop it
1 x Front 2" Bump Stop Drop Blocks
1 x Rear 2" Bump Stop Drop Blocks
1 x Set Stainless Steel Extended Brake Lines
1 x Front Panhard Rod
1 x Rear Panhard Rod
1 x Set Adjustable Rear Upper Control Arms.
2 x Breather Extensions
1 x Emergency Brake Cable drop bracket
What you will also get:
3 OEM Toyota oil filters - brand new in the box
1 SLEE fog light wire harness
fuel: gas
odometer: 147,xxx
title status: Clean
price: $16,000
MECHANICAL
new water pump
new o2 sensors
new EGR valve
new hoses
new plugs and wires
new Toyota belts
ARMOR
ARB Front-Bumper
WHEELS AND TIRES
AUDIO
LIFT KIT
Kit Includes:
2 x N60070L Shocks
2 x N60071L Shocks
