For Sale 1996 Locked FJ new leather seats, 4x4 labs bumper
Factory wheels sold...
The bediner was done professionally by a linex Dealer....I color matched it with the toyota paint.
The holes were filled by me.... I took Metal epoxy and fiberglass screen and filled the holes and sanded then primered...looks great....
Had toyota replace the heater box and clean the vacuum within last two years... All new rotors and new pads within last 3 months..New tires less than 300 miles on them...
Possibly sold, Taking back up offers...
Sure. Four 0 4- Five two 0- 02five nine . Call anytime. Thanks!
Rob
There is a lot... you have to unscrew all the rivets after removing the flares... im guessing it was like 8 to 10 for each fender in front.. the back door you have to drill out some brackets, it might be 6 for each door, then the quarter panel might be another 8 holes for each side..
After I did few holes The metal epoxy was great, use sparingly and you have minimal sanding... the first few holes I was using a spackling technique like joining sheet rock.... DONT DO THAT... it took me days to sand back the epoxy... use the technique and use very little and treat each hole like you are filling "nail holes" in the wall and smear it over the hole with the screen.... almost no sanding then..
I was lucky that the "gasket" which is a rubber adhesive was dried out(so the fenders were not stuck to the truck" ...if the fenders are not stuck to the truck you are ready to remove....So when the fender is free, you slide or push the fenders forward toward the front of the truck, it should slide right off,. Alternatively, the fenders have tabs, so if you don't care about saving the fenders, you can just rip them off. But be careful not to flex the fenders or body as you pull them off.
The mesh I am referring to is fiberglass tape mesh. and yes about 2 inch squares. I would hold the squares with one finger and smear the epoxy in a downward motion, pushing the epoxy through the screen and through the hole. I hope that helps... I should have taken pictures...
Can't PM you for some reason. Am in Bay Area and interested, give me a call: four one five, 260, one seven three eight.
