1996 Alternator disassembly
Bountiful, Utah
Any one have some experience with the disassembly of a 1996 LC alternator. I have it off, pulley removed, regulator off and now its case separation time. Toyota has both bearings and brushes for about $50. A factory rebuilt is just north of 200, hence the reason for the self rebuild. Any help with pitfalls to avoid that will allow for a successful operation would be great
Since your not getting any love with your thread I will offer this though it has been a while since I did it. I don’t know if the Toyota 80 amp small case and the 130/150 amp large case alternators are constructed the same. Having given my 80 amp to help out another Mud member I can’t check for you. I took apart a 150 amp large case to replace both bearings and to powder coat the case. I had to make a special puller to get that one bearing out. Also in order to get the case apart I had to cut the large welded copper connections. For reassembly I welded the copper back together. I don’t know if you have the equipment to weld copper if you are going this route so maybe they could be silver soldered or something. The heat that process creates might be a problem though??
This may be useless information if the alternators are different. If they are the same everything except for that one bearing is quite simple to do if I remember correctly. HTH
Bill
Alternator disassembled and waiting for parts
SO, thanks for the reply. Its nice to know someone out there cares. Well I was not offended by the lack of love so as with most things I decided that if no one had a clue, it was time to become an expert. sooooo. since this was a factory 80 amp unit and I was down to the split the case and make my own instruction book or send it in a s core on a rebuilt.
I opted to go for it. So for any of you RKI's (reasonably knowledgeable individuals) out there, here are the details. I found a small puller that i attached to the three studs that hold the regulator on the housing. I separated the case and removed the 4 screws that held the front bearing cover in place then tapped out the bearing from the case with a flat punch. The rear bearing was a different story. I supported the edges of the case with wood block then tapped the end of the armature with a dead blow hammer untll the armature separated from the other half of the case. The bearing rather than staying in the case stayed attached to the shaft of the armature. This required a small three jaw bearing puller to pull it off the shaft. Be careful because the end of the shaft is not all steel. Its a non conductive material that will chip if you hit it wrong. so after all that, I called our friends at Cruiser Dan's place of employement and ordered the two bearings and a brush set. A grand total of just under 50 bucks. It will be a breeze to reverse the procedure. I'll post an update when i'm back on the road. Kind of a long solution to a small problem but $125.00 saved is $125 earned!
I was looking at the charging system in the FSM the other night. It provides detailed procedures for testing/inspecting/replacing all parts of the alternator (generator as Mr. T refers to it).
PM me if you would like me to scan and email to you.
Good luck!
I replaced the bearings in mine before Cruise Moab last year, didn't take pix, etc. For sure didn't do any soldering, welding, relatively easy job, used common tools and the FSM for guidance. IIRC there are a couple of areas where care was needed: The rear end of the stator has some plastic insulator coating, so be careful when pushing that bearing and there is a washer/spacer under one of the bearings that can be easily deformed.
So here goes the end of the story. I got the parts last Friday and reversed the dissassembly order (FSM Big Red version). FYI I did note the aluminum bearing keeper that could have been mangled (fit back nicely) and also noted the plastic coating as noted by tools R us in his post. Being careful not to gorilla tighten all screws and case nuts, it went back together quite nicely and after about 30 min it was back in and running. Everything seemed perfect.
So last question I have..... the wine I had traced to the alternator bearings is still there. Humm. Prior to putting everything back together I started it without the alternator and it ran perfect no whine. The only other thing that belt runs is the water pump. Anyone have experience with a whine coming from the water pump or fan clutch.
I'm not going to worry about the alternator any longer. One bearing was rough but was not the real problem. Any thoughts from you rocket scientists our there.
In my experience, the "alternator whine" is caused by 2 things:
* Most often it is caused by the use of cogged belts. The only belts you should use are Toyota belts from your dealer or Cruiserdan.
* Next most often cause is the alternator belt tensioner. It is relatively cheap and easy to replace.
Use a mechanic stethoscope or a long wooden dowel to isolate the noise.
-B-
