1996 80 series ECU problem?
SoCal
Need help with troubleshooting electrical problems with my Cruiser. Here's what has transpired since last Thurs 1/24: Drove the Cruiser up out of L.A. to Panamint Valley. Engine ran great (also towing a heavily modified Aliner trailer). Pulled off the pavement, onto the dirt (where she belongs...) and within 200 ft of leaving pavement, started to lose power, then engine died. Tried to restart, the engine turned over but wouldn't start. Waited 4 - 5 minutes, started up no problem, and then again after another 100 ft or so, died again. I played this game for awhile until we got tired of it and my spouse hiked up ahead to our intended camp spot where my brother and other friends had arrived earlier. Got a tow up to the camp spot.
So, we popped the hood and with the help of a LC shop owner camping/hiking buddy (40 series expert), we found several things: 1) major crack in the air intake line downstream of the mass air flow sensor. Okay, no problem, used the handy role of duct tape, and taped the crap out of it, 2) found the small diameter nipple on the "gas filter" (as it is called on the diagram on the underside of the hood) had broken off and was stuck in the tubing. No problem, we taped the broken end off, and re-routed the line to another location so that the proper vacuum was achieved.
Then, fired up the Cruiser no problem, drove around up a steep bumpy hill for 5 - 10 minutes, ran like a champ. Problem solved?? Hell no.... Next day, several of us headed down the road to the hwy to get to a trailhead for a nice long day hike. The problem came back. Same thing, ran a few 100 ft, engine sputtered and died. We checked the prior day's patch job, and re-did the duct tape temp repair mentioned above. Got out to the highway, drove about 6 miles to the trail head at 55 - 65 mph, no problem! We then turned off of the road to head toward the trailhead, problem surfaced again. But this time, the engine would not start. It would turn over, but not start. I have a scan gauge installed and it threw several codes including a PO300 and a host of others. So we rolled the Cruiser down hill on the highway (with a buddy following with emergency blinkers on) to get to a SAT phone at a local campground/resort to call AAA. Prior to the flatbed showing up, I decided to try to start her up one more time, same problem, no start however this time the scan gauge showed nothing, nada as if the ECU and the scan gauge were not communicating. Got the Cruiser to a shop 73 miles away and after spending the good part of this past Monday troubleshooting, the shop found: 1) fuel pump was dead, pulled and bench tested it and nothing. Also, no power to the starter, injectors, nothing. He pulled several relays (including the EFI) and bench tested them and they worked fine. Put them back in, nada. He checked the ECU and it had power coming in, but nothing coming out to the various devices, relays, etc. His conclusion is that the ECU is indeed dead. If so, what could have caused the problem?? I also consulted with a LC shop and they're a bit surprised that the ECU would be dead as apparently they don't go out too often. I've read several posts about this on MUD and same feedback that these things don't die that often and that other things such as fusible links, could be the source of the problem. I need to verify tomorrow that the shop checked the fusible links.
I'm planning to have a flatbed take my Cruiser from the shop it's currently at to the LC shop as they have a used ECU they can use to verify whether mine is dead or not. Want to do this before spending over $1k for a new one (got a quote from AT) However, assuming it is, what could have caused it? Don't want to put in another ECU just to have it blow too as these are way major $$$ as everyone knows. So anyhow, is there anything else I should have the current shop check before sending it to the LC specialist?? Could save me money if the current shop can diagnose and fix the problem and not have to bring to shop #2 .
Thanks in advance for any suggestions!
Check your fusible links at the battery.
If you don't have proper voltage under load, go to your nearest Toyota parts dealer and buy a fusible link set. It's all 3 wires and pretty easy to understand what goes where. Find it on your + battery terminal. Disconnect the - battery terminal and then change out your fusible link.
Computers (ECUs) don't usually go stupid and then come back. I'd say that shop is guessing at the problem. You are wise to move it to another shop.
blkprj80 - Thanks for the prompt response. Yea, my buddy with an 80 suggested the same (look at and replace the fusible link) as it is a common source of similar symptoms from other posts both he and I have read. The only thing is, do you know if this would solve the problem of the ECU getting 12v, but no output?? This is what the mechanic said was occurring.
Regardless, I'll call the guy this morning, and verify whether he checked it or not. Plus, I'm concerned that the dead fuel pump is/isn't just a coincidence. I had it replaced about 3 - 4 yrs back so surprised that he bench tested it and found it bad.
By any chance, did you get the following codes?
P0300: Random/mulitple Cylinder misfire detected:
P0301: Misfire detected:
P0302-306: Cylinders 1-6:
Trouble Areas: Ignition system; injector; fuel line pressure; EGR; compression pressure; valve clearance not to specification; valve timing; mass air flow meter; engine coolant temp. sensor.
Yes, as I stated in my very lengthy thread (sorry...) it threw a PO300 code, plus a few others. To be honest, I didn't think to write them all down (dumb a**...).
I just talked to the mechanic and he visually looked at the fusible link, but not output voltage, but will now check the 3 wires on the downstream side with a voltmeter. He also mentioned that the fuel pump was dead, he put a new one in, and still nada.
Well, the fusible link is NOT the problem. The mechanic checked voltage on the 3 wires coming from it, all have 12v. And he confirmed again that the ECU has 12v plus a good ground.
So, planning to call AAA this morning to have them pick it up from the shop in Ridgecrest and bring it to MAF in Simi. Unfortunately the distance in miles is beyond my 100 mile free tow coverage, sooooooo, another $$$ to get it there.
Thanks for the suggestions for troubleshooting and am hoping that MAF gets to the problem quickly without too much damage to the wallet.
sorry to hear that bro. Regarding AAA, would it be financially beneficial to upgrade to the Premier membership in order to avoid paying a high tow bill? This pays for a 200 mile tow and your distance from Ridgecrest to Simi Valley is 150 miles.
How did he check the fusible link?
If it burned out, you might still see 12V on the other side if it is not under load. Your meter is megohms input.
Kind of like a weak battery connection. You have 12V until you try to start it, then it goes to 0.
I hope it turns out to be something easy and low dollar. Can you have someone tow it 99 miles and then hire someone else to go the rest of the distance? Or will your insurance company cover the first 100 miles for you?
Good luck with it!
And, have you replaced that air intake hose yet? Do that first. Reading your post again makes me think it is a good part of your problem. You taped it, it ran but died the next day. You re-taped it and ran 6 miles, but went to s*** when you were on rough roads. Then it wouldn't start. The MAF needs to see air flow to demand fuel, I'd think. Rough roads may have opened up that intake tube and starved the MAF and the fuel stopped. Duct tape gets gooey when it gets hot.
Regarding the AAA tow, I did upgrade to the 200 mile plan this week, but there is a 7 day "wait" period, so people like me don't try to take advantage of my current situation. Even though I'm a 25 yr. member (and pleaded my case), the gal couldn't help me, although she was really sympathetic.
I did look into having it towed a distance less than 100 miles and then finding a friend with a truck/flatbed to haul the rest of the way, but don't know anyone. Total tab from tow (on my dime) = $350 (major bummer...).
blkprj80 - The mechanic was very confident that the fusible link wasn't the problem. He did put his meter on it, move the wires around to see if there was something loose, and never lost 12v, however you are correct in that with no load on it, it could make a difference.
My rig is now at MAF in Simi, and they confirmed the ECU is NOT bad (thank G**), however now what is the problem??? Their gut is wiring harness thru the firewall, which has also been a problem that other's have encountered from reading other posts. MAF did find that both of my batteries were dead on arrival, WTF??? MAF used one of their's to test out the ECU while putting mine on the charger. Hopefully they haven't expired completely and find out today. Interesting, the owner of MAF is having a similar problem with his kid's rig. When MAF finds the problem, I will update my post in hopes that this can help others in the future.
Blkprj80 - Forgot to answer your question about the air intake. No, haven't replaced it yet. The new one showed up at my doorstep yesterday. The old one was cracked almost completely around so most likely has been in bad shape for quite some time so would have thought this problem would have surfaced earlier, particularly since I take it off road quite a bit, but maybe not.
Saw a starting/running problem like this recently (coincidentally in the Panamints!)
Turned out to be a clogged catalytic converter, although it wasn't an 80.
Can't say about the ECU though.
The dead batteries could be due to the mechanic living the key on IGN for troubleshooting and then forgetting about it?
Yea, that's what I'm thinking. My ignition battery is a 4 month old Costco/Kirkland, my utility is an Optima blue top so agree, best bet is that he left the ignition on and forgot about it. I'm hoping they hold a charge and should find out here shortly.
Man, can't wait to find out what the hell is wrong with my Cruiser......
A Bad Day in Panamint!
:crybaby: The boys trying to figure out Brians gremlin. Even Mark (the bearded one) from Marks Offroad was stumped!
I wasn't much help
:popcorn:AND NO!!! That's not MY Heep behind me.........
Nice pics! Still, good memories were made I bet.
I wonder if by some slim chance the fuel pump power circuit got shorted out inside the tank? This has happened to couple of folks where the wire abrades itself against the pump framework. But the fuse would've blown I'd hope.
Yea, I thought of that too. It seems too coincidental that the fuel pump went out at the same time that the other problems surfaced.
Hey Rubi - Thanks for sharing the pics of my rig being torn apart! And hey, is that you sitting on my seat in the dirt? (haha). Where's the Jack???
