ARCHIVE 1995 Manual Transmission Turbo Diesel Land Cruiser: GTurbo, Dobinsons Suspension (MRR Adjustable), PDI intercooler, NPC Clutch & Flywheel & much more
This 1995 Toyota Land Cruiser HDJ81, a Japanese-market model, was imported into the US in 2021. With 143,945 miles on the odometer, this Land Cruiser is finished in Toyota Dark Emerald Green (color code 6M1) over a matching cloth interior. It is powered by a robust 1HD-FT 4.2L 24-valve Turbo Diesel inline-six engine, paired with a 5-speed manual transmission, a dual-range transfer case, and a locking center differential.
The cabin features cloth seats along with a matching dashboard and door panels, offering a comfortable and functional driving environment. Additional amenities include automatic climate control, a ceiling-mounted altimeter and compass, adjustable side bolsters, and power lumbar support. The steering wheel frames a comprehensive set of gauges, including a 6k-rpm tachometer, 180-km/h speedometer, and gauges for voltage, fuel level, coolant temperature, and oil pressure.
Service records are extensive, including inspection records from Japan dating from 1996 to 2018. The vehicle comes with one key and the factory cut original template from Toyota, as well as the factory manuals. This vehicle comes with complete import documentation and a clean Florida title.
Modifications and Enhancements​
This Land Cruiser has been modified and enhanced for both performance and aesthetic appeal. Key modifications include:
  • Suspension and Wheels:
    • 2.5-3” Dobinson springs
    • Dobinsons MRR adjustable shocks
    • Black Mickey Thompson Classic III wheels with 35 inch BFGoodrich KO2 tires
  • Performance Upgrades:
    • Short shifter
    • GTurbo green wheel upgraded Turbo sustem
    • Torfab air intake box
    • PDI front mount intercooler
    • Manta 3” exhaust system
    • NPC Performance 1300NM clutch including slave
    • NPC Performance Flywheel
    • AEM oil pressure, EGT, boost, and oil temp gauges on a 4x4 concepts 4 gauge pillar pod
  • Exterior Features:
    • Custom front bumper with Warn evos 10,000lb bumper integrated winch, designed in JDM OEM style by Land Cruiser Heaven SE
    • Repainted grill, bumper, fender mirror, and hood to address stone chips
    • OEM fender-mounted mirror, mud flaps, and aluminum side steps
    • JDM swing-out spare tire carrier
  • Interior Upgrades:
    • Momo steering wheel
    • Android head unit compatible with iPhone and Android devices
Mechanical Preparation​
In preparation for sale the following maintenance and repairs were performed to ensure optimal performance and reliability:
  • Replaced engine air filter
  • Replaced fuel filter
  • Oil change and oil filter replacement
  • Removed and replaced front brake pads
  • Removed and replaced rear brake pads
  • Adjusted emergency brake
  • Greased driveshafts
  • Replaced rear main seal
  • Front right and left wheel spindle nut adjustment
  • Rear left wheel hub adjustment
  • Retorqued all suspension components
  • Rotated tires
  • Vacuum and recharge air conditioning system
  • Removed and replaced evaporator core, dryer, and expansion valve
  • Oil, brake fluid, transmission fluid, and antifreeze were replaced
  • Two new batteries installed
  • OEM alternator reconditioned with new brush kit, bearings, and rotor shaft maintenance
  • Fresh timing belt and water pump installed
This exceptionally well-prepared and modified 1995 Toyota Land Cruiser HDJ81 is now available for sale. For more information or to schedule a viewing, please contact Uncommon Motor Cars.
We have hundreds of additional exterior, undercarriage, interior and engine photos available upon request or on our site: 1995 Toyota Land Cruiser HDJ81 $53,950 — Uncommon Motor Cars - https://www.uncommonmotorcars.com/inventory/p/1995-toyota-land-cruiser-hdj81-53950
Asking price: $53,950 OR BEST OFFER
I can’t believe I’m saying this, but this is the first post from this seller that is not outrageously priced. If somebody wants a Gturbo/intercooled manual 80 and doesn’t mind paying $50k+ for an RHD, doesn’t mind doing the rest of the major maintenance, and is willing to pay 100% of MSRP for all mods this is their bet.
Curious that the maintenance went as deep as alt rebuild and A/C system, but ignored obvious hub rebuild and did the Gturbo/PDI install (assuming fuel is turned up too) with no valve clearance or injector service.
From OR to FL via Canary, dangit.
