Matt Sierra
GOLD Star
Hi all, recently purchased a 1995 HZJ75 and am in the process of getting the rig titled, registered, and ready to go home. Looking forward to tapping into this great resource!
Thanks, I’ll start there. It’s not too crusty overall, but corrosion often seems to pop up around grounds.Congratulations and welcome, I have a 1992 and they are great trucks. Most parts are readily available from your local Toyota dealership.. For the oil sender, check your grounds and the connection at the sender on the engine as a first step.
Cheers, James
Hard to be 100% certain with this photo, but the cab vent looks to be 75 Series.Hello,
Nice truck.
The cab appears to have been replaced with a 79 Series one. Which means you have a few inches of extra leg room.
Juan
Hard to be 100% certain with this photo, but the cab vent looks to be 75 Series. View attachment 4092995
Yep, I think the 79 Series cab vent is 2”-3” longer than the 75 Series version. The smart folks can chime in with the exact dimensions.Hello,
Both 75 and 79 Series have the cab vent. The latter has a slightly longer one.
The vent, the windshield, the roof and the Land Cruiser badge give it away as a 79 Series cab, namely a post-2006 one. The front clip is from a 75 Series.
Personally, I think it is worth because of the extra leg space.
Juan
Hello,Yep, I think the 79 Series cab vent is 2”-3” longer than the 75 Series version. The smart folks can chime in with the exact dimensions.![]()
Assuming there has indeed been a cab swap, you’ll enjoy that extra 3” of legroom. It doesn’t sound like much, but it makes a significant difference in overall comfort.Interesting, thanks for the info. I don't have a lot of details about what's happened on it's journey from Australia to Oregon but it did make a stop in Dubai for a respray. Maybe that's when they swapped the cab?
Hello,Interesting, thanks for the info. I don't have a lot of details about what's happened on it's journey from Australia to Oregon but it did make a stop in Dubai for a respray. Maybe that's when they swapped the cab?
Maybe this is a silly question, but would this jeopardize his ability to register it in the U.S.? It depends on what the VIN says I guess, but would the VIN say it's a 2006 or newer Land Cruiser?Hello,
Juan
Hello,Maybe this is a silly question, but would this jeopardize his ability to register it in the U.S.? It depends on what the VIN says I guess, but would the VIN say it's a 2006 or newer Land Cruiser?
Hopefully not. This is a beautiful truck man! I have a 1997 HZJ77 here in Colorado and I love it.
You're stating the obvious, but that's fine! I was worried maybe the firewall was included in the conversion. I know whenever I needed to show the VIN, the only plate they cared about was the one on the firewall.Hello,
I may be stating the obvious here.
70 Series trucks have the VIN number stamped on the front part of the right frame rail and on a plate that is riveted to the firewall inside the engine bay.
If the conversion was done properly, the plate went from the old cab to the new cab. Provided, of course, they kept it.
Juan
