You would be amazed how difficult this is for some people....This is a valid point.
But it is better to learn from the mistakes of others than by your own experience.
I used a huge moving blanket to loosen the cap and let the pressure out. I wasn’t concerned about get burnt
Don’t some year models of the 80 Series have the same or similar engine? (1FZ)You know this is the 80 forum, right?
To answer your question (which no one bothered to do, while they were berating you for all the stuff you did do), yes you can test a coil.
It's a transformer, so it has two sides, a low side and a high side. You'll need a mulitmeter (digital or analog, doesn't matter). You'll also need the specs for the FZJ73 engine components, which will be in the 70 series factory service manual. There is also a testing procedure in there (OK, that's an assumption on my part, I've never read a 70 series FSM, but it's in every other FSM I've ever read, and I've read a few). That'll tell you if the coil is good or not.
From the OP's original statement, I thought this was appropriate......
This thread reminds me of someone asking for a bandaid and being told how many ways they could have avoided being cut in the first place.
