Are you using the fuel pump assembly?
No, I had to use it in the 93 I am working on. The one I pulled out is no good.Are you using the fuel pump assembly?
Ok. Thank you sir. Hope everything goes well with the build.No, I had to use it in the 93 I am working on. The one I pulled out is no good.
If you need a fuel pump assembly I have a brand new one in the garage I bought a few months ago. Was chasing down a problem and it ended up being something else so don't plan on using it.Ok. Thank you sir. Hope everything goes well with the build.
Pm sentIf you need a fuel pump assembly I have a brand new one in the garage I bought a few months ago. Was chasing down a problem and it ended up being something else so don't plan on using it.
goneLeft side tail light still available?
Do you have the passenger side tail light still?Yes,
I am heading out to the Fall Cawl. I will try to pull it out when I get back. If you have not heard by monday give me a shout.
I do not.Do you have the passenger side tail light still?
I think I am going to hold on to that for now. I will let you know if I decide to sell it.PCM? How much?
Let me look. I have been slack about getting back to everyone. I will try to do better.Do you still have the dash pad? Interested in one that is in better condition than mine.
No worries. I'm in Virginia also so I might be able to pick up if you're not far. I'm 20 minutes south of CharlottesvilleLet me look. I have been slack about getting back to everyone. I will try to do better.
It did not have one.Did you keep the drivers sun visor by chance @matzell ?
