1993 vs. 96- engine swap possible
NY and AZ
There used to be info on the differences between years but I searched in the FAQ and only found the section on differences for 95,96,97.
92's are the last year of the 3FE correct?
Will a 93 engine swap directly to a 95+ cruiser more or less?
or if someone knows the link that would be great. Thanks
93 & 94 are OBD 1 and 95 is OBD 2 so you will need the 93 engine harness and ECU. Plus the transmission was different, not sure if the bolt pattern changed... probably not, someone else can weigh in on that one.
In states that put stipulations on engine swaps, it is generally not allowed to swap an engine that is older than the vehicle it is being installed into.
Thanks guys! That is very helpful.
