Build 1993 refreshed (now gone) and 1995 build up with new OEM engine
Member Build Threads
Test fitting, I like to do that before I lay down FIPG and torque.
Cheers
Pans are on, timing cover is on, new oil pump gear and rotor set, new timing chain and guides, new oil pickup/strainer, all oil pressure relief valves are new, new Aisin water pump, oil pressure sending unit new, new thermostat and new harmonic balancer.
Assembly is going to slow as I get to the head. Few little things I can do here and there but I have decided I want to go with a new OEM head, cams, valves and all that. I did get some ARP head studs already in prep.
Cheers
This showed up today.
Sure is pretty but still need cams and valves and with the current situation we are all dealing with I am not buying those anytime soon.
Cheers
Sold my 93 this morning. I will miss it, it was a killer Cruiser.
So next week I will start buying what I need to finish up the 95’s engine and put the Cruiser back on the road. I will do all the basics like knuckles and brakes. I will also do a lift, tires and sliders.
Cheers
Ordered:
-Cams
-Valves and related parts
-Bunch of misc engine parts
-DBA rotors, pads and braided lines.
-Knuckle kit with WB
-Tre's
Pending:
-105 steering box upgrades, sending my box to Redhead just deciding if I want to upgrade.
-??? shocks
-Reman calipers
-Lift
-Tires
Cheers
Oh ya, got some goodies already saved up for it too like new OEM engine and trans mount. Drivers seat cushion and more. 😋
Cheers
Had it out of the shop today for the first time since October.
Behind the sexy 45-series. 😋
Just waiting on a box with cams and some other parts in it. I hope to begin on assembly of the new head this weekend.
Got remanned calipers in hand but haven’t ordered the 105 sector shaft and pitman arm yet.
Cheers
Looks like I may not see the cams until Monday, unless I get lucky with shipping.
I did order the 105 sector shaft and pitman arm for the Redhead rebuild. I also ordered a p/s pump, reservoir and high/low pressure lines.
Cheers
NEw OEM brake booster and 105-series spindles purchased this evening. New lower u-joint on steering column and new wheel studs for the front hubs.
What can I say, I like new OEM parts! This Cruiser is also (to-be) my companies “flag ship” so it’s easier for me to justify this way. 🤣
Cheers
Had this for awhile. Bought two when I did the seat in the 93.
Stereo stash, JL amp and super nice sub with the head unit.
Goodies, ARP head studs in the box.
Suspension bushings and bolts/nuts/washers for days.
Cheers
