I'm working on installing new springs (OME 850) and can't get the axle down enough with the brake line attached. My brake line goes down on the driver's side to a 2-way splitter with two hardlines, one for each wheel. I can't see a way to gain another 3+" of slack without taking it off. So, if I'm going to remove it, I might as well upgrade it.
Is there an ideal replacement available at your average parts store that has some more slack? I read that a 1985 SFA mini truck uses a 5" longer line that swaps right in. However, since it seems like a lot of people have a different setup (maybe newer trucks are laid out different for diagonal braking or ABS reasons?) I don't want to buy a new line that only works on an FZJ.
Is there any trick to getting the old lines off?
