1991 engine options
West Jordan
I was just curious if the 4.0 inline 6 could be replaced with a 4.5 from a later year? Does the edu etc need to be changed? I am looking at fixing up a clean 91 despite the fact that the current engine is blown. Thanks in advance.
Everything is different. EVERYTHING! Find another 3FE and put it in.
Either get another 3FE or swap for something non-Toyota.
22RE all day long. For one, it's like, 19 times better than the 3FE, plus, it has the letter R in its name, so you know it's going to make a lot of power.
^heh^
How much work and $ you looking to put into it? Or... Even better... How much is acceptable? :D
When mine goes tits up... Ill either put a diesel (havent yet thought about which, so hope my motor lasts a while) or rebuild what I got.
^heh^
I wanted to spend about 4k. Plus some extra goodies along the way.
Since you didn't say you'd do any work, I'm assuming you're going to pay someone to do it. $4000 will get you your stock engine rebuilt with basic parts, and that's about it. The general rule of thumb is to go figure out how much that engine swap is going to cost, then double that figure to find out what it's really going to cost. You can't be a budget baller with these trucks, and 4k is about halfway to what you'll need to do a swap with an engine worth the effort. Yeah, you can go find some piece of s*** junk yard 350 for $200, but you'll end up spending dollars to save dimes. And honestly... if you're asking if the ecu has to be changed, then you're probably not going to pull the swap off yourself. There's a huge difference between reading about it and doing it, and the reason why turn key swaps cost ten grand is because it's a lot of ******* work and there's a lot of ******* knowledge, experience and skill involved. If you haven't already bought the truck, your best bet is to buy one that doesn't need engine work. If you do already have it, either rebuild the stock engine or part it out, cut your losses, and start with a running rig. I know it sucks to hear all that, but I'm not gonna bull**** you with some delusions of grandeur. Life sucks, but it sucks worse when you're lied to, and that's not what I'm about.
Just remember when you do and engine swap Chevy or whatever you have to become the expert at that engine and your swap.Shops don't want to work on them,Because their not sure what has been changed and or where.There is nothing wrong with swaps as long as you know this in advance.Yes they are alot of work.You will spend countless hours searching the net for info.If you have a shop do it,when your out on the trail and it breaks your not going to know how to get it back on the road.It will have to be hauled back to whoever you paid to do the work the first time,"if there still in business.That being said good luck in whatever you do.I would stay with the Toyota engine if you can. This after I put a 4.3 into and 85 Toyota extra cab.Yes it is a smog legal swap but it was probably close to 9 or 10 grand to complete.
