I finally got my 2wd mini back from the brother in law. I took it on a short road trip 150 miles, Intermitintly it will start bucking, under throttle, limiting speed to under 50 mph. It seems worse when going uphill or down., If i shut the truck off for just a few minutes the problem goes away. When cold I can jump in and everything is fine. the round trip to work and back 14 miles no sign of problem on one trip then randomly appears on the next. With all of this going on over two mountain passes hauling a spare box for the truck, I still got 27mpg. Bucking and all still beats the hell out of the 13 mpg in the 60..
I done the following
Replaced plugs, distributer cap, rotor, air filter, oil and filter change.
tested tps has constant increase in ohms from idle to full throttle no dead spots.
any help would be much abliged.
