1990-1992 brake master, disk conversion, help
Golden Colorado
Website
forum.ih8mud.com
here is the scenario, I have a JDM 1990 HZJ77 with factory 4 wheel disk brakes. I am search of a master cylinder that might work. I have in my possession a 1990-1992 80 series master cylinder. The brake lines match up and the 4 hole mount is identical and it appears to be a match. However the master cylinder was from a front disk rear drum application. The 95 on was 4 wheel disk to my understanding, but the lines don't match up.
So the question is, has anyone done a rear disk conversion and kept this master cylinder? Is there a residual valve that can be removed?
Picture of the rear drums, I believe they might be the same as a FZJ80? Not really sure, 80 series are a bit Greek to me.
I put a 94 disc rear axle on my 92 and used my stock 92 master cylinder if that is what you're asking
