- Location
- United States
Hello
I am selling 1989 Toyota Land Cruiser FJ75 troopy.
LHD. Original 3F straight 6 engine with 5 speed Trans. Driven 250k
Engine starts quick, great idle, strong. No overheating.
The frame solid. No signs of weld or rust.
About the body, couple of issues, The rear tub has rust around the center of the floor, pulled out the carpet to see the condition. The wheel wells and the floors around the wheel wells are solid with no rust. The rocker panels have no rust ( see pictures of underbody ). The doors are solid with no rust. The rain gutters have no sign of weak spots and has no rust. The hood is straight and no signs of bent or rust.
The front driver side top fender has gone inside about 1/2 inch. If you notice the front driver turn signal light, you will see that it is little bit bent inside at the bottom compared to the passenger side. After taking out the front grill i saw that there is a 1/2 inch bent in the support sub assembly where the top fender and driver side headlights sits on. Its a small metal support piece that attaches to the radiator support bracket. It is replaceable. Obviously the car has been hit in that spot. Few metal body parts have been bent in this hit but does not look very bad. The front Panel valance is bent. Since the support sub assembly has been hit, it made the valance bent with it. Between both these parts sits another Support bracket that holds both pieces, this piece is bent 1/2 inch.. I believe the previous owner couldn't find the original sub assembly pieces to replace them. But they are plenty of it in the market. No issues finding these parts.. Total cost for the 3 parts above is $230.00 not including shipping.. If these parts are replaced then the top fender piece will go outwards by 1/2 inch and the driver side signal light will be straight..
It has original factory air conditioning and heater.
It has dual Gas Tanks.
At the moment it does not have its original seats bolted on the car. The original front seats are available but they need upholstery. As for the rear, there is only 2 seats for the troopy, not bolted in.
All the dash parts are in place.
If the problems that I have addressed can be repaired fixed then it will be a great troopy. Yes It will need quiet the work to get this baby looking good. If someone has the place and the right equipment to tackle these issues, then in no time this baby will be all worth it.
It will need new tires and wheels unless you like 2 piece wheels. It needs seatbelts, door trimmings and weatherstrips.
Comes with clean Montana Title. It has 3 vin numbers locations. Vin plate on firewall, chassis, driver door. All match.
The vehicle is located in La Crescenta, 91214, CA.. My email is Edmond4822@gmail.com or you can call me at 818-281-2223
For more information, feel free to contact me with any questions. You are more then welcome to inspect and test drive the 75.
I will be happy to speak to you about it.
Price $14,000.
Thank you.
Price $14,000.
Thank you.
