Parting Out 1986 FJ60, 1988 FJ62, and LS Parts in OR
Oregon
Hello Mudders,
I am finishing up a LS swap into my FJ60 and have a boat load of parts laying around that I need to get rid of. I am located in Portland, OR and am willing to ship things to wherever. I will upload photos but more are available upon request.
Once my truck gets back from the exhaust shop, I will start a build thread as well to show some lessons learned.
Below is each item or part, with part number that I have, and my suggested price. If an item is listed multiple times that is the quantity I have on hand. I also have all of these items listed on the Portland Craigslist page.
Blue Sea ANL Fuse Block with Insulating Cover 35-300 amp 5005 $18.49
Rockford Fosgate ANL Fuses ANL150-10 150 Amp ANL150-10 $10.00
Blue Sea Systems ST Glass 6-Circuit Fuse Block with Negative Bus and Cover 5015 $27.70
Blue Sea Systems MRBF Terminal Fuse Block 5191 $20.61
Blue Sea Systems MRBF Terminal Fuse 75Amp 5180 $15.45
Blue Sea Systems MRBF Terminal Fuse 200 Amp 5187 $15.45
Bussman Series ARC Fuse Block, Rear Terminal 15712-14-06-21A $39.78
Advance Adapters Inline Temp Sensor 1-3/8 x 1/2 716673A $65.88
FJ60 Arm Rest Used $10.00
Dayco Top Cog 22625 Accessory Drive Belt 22625 $19.97
Dayco Top Cog 22425 Accessory Drive Belt 22425 $9.59
Armor Mark V Belt Gates 9500 Dayco 17500 Goodyear 17501 Cadna 17500 17500 $12.50
Fj60 Brake Booster Vacuum Tube Line 44763-60020 $24.00
FJ60 Brake Caliper Rebuild Kit 9/75 - 1/90 Toyota OEM 34479-00031 $58.58
FJ60 Disc Brake Hardware Kit 1/75 - 1/90 Toyota OEM 084-05A-Kit $10.00
Fj60 Carb Cooling Fan Used $30.00
FJ60 Caster Correction Shim (Six Degrees) Pair 99-600B $24.79
FJ60 Choke Cable Used $65.00
Fj60 Cooling Fan Relay Used $24.00
FJ60 Dash Grab Handle Used $75.00
FJ60 Distributor Cap OEM 022-02E-OEM $24.00
FJ60 Distributor Rotor OEM 022-03C-OEM $12.00
FJ60 Door Latch Inside Striker Yellow Zinc 130-08A-U $22.00
FJ60 Door Latch Inside Striker White Zinc 130-08A-U $22.00
FJ60 Door Lock 130-05A-U $45.00
FJ60 FJ62 Lift Gate Lower Weatherstrip 139-07A-U $65.00
FJ60 Door Seals Used
FJ60 Front Scuff Plate Door Sill Seal Protector 114-126B-G $66.00
FJ60 Rear Scuff Plate Door Sill Seal Protector 114-127B-G-U $15.00
FJ60 Emissions Control Module 89550-60130H $25.00
FJ60 Fuel Door Release Cable Used $35.00
FJ60 Fuel Vapor Manifold 77193-60030 $26.00
---- SOLD ---- FJ60 Hand Throttle Cable 177-24 $40.00
FJ60 Headlight Cleaner Relay 194-90A-U $25.00
FJ60 Headrest Used $30.00
FJ60 Hood Release Cable 177-26A-U $45.00
FJ60 HVAC Climate Control Heater AC Fan Speed Complete Used $50.00
FJ60 Gray Door Handle Bezel Trim 130-41K-GY-U $13.00
FJ60 Carburetor Insulator Plate 042-02H $115.00
---- SOLD ---- FJ60 Non-US Intake 012-20L-NS-U $100.00
FJ60 Oil Pan Gasket 549-213 $15.00
---- SOLD ---- FJ60 Oil Pressure Sender 83520-35032 $30.00
FJ60 Power Door Lock Solenoid 130-85A-L-U $50.00
---- SOLD ---- FJ60 Radio 191-01C-U $100.00
FJ60 Rear Window Wiper Motor 192-80K-U $100.00
FJ60 Main Relay OEM 90987-02004 Used $10.00
FJ60 Saginaw Pump Bracket Adapter 2F Engines 40-4152 $120.00
FJ60 Shifter H42 4 Speed Used $35.00
FJ60 Shifter Bushing 33548-60020 $15.21
FJ62 Lower Shock Bushing 102-30M $4.67
FJ62 Front Upper Polyurethane Shock Bushing 102-31M-P $3.00
FJ62 Front Upper Polyurethane Shock Bushing 2 ea 102-31M-P $3.00
FJ80 FZJ80 80 Series Shock Cusion Retainer 2 ea 102-33M $10.00
FJ62 FJ80 FZJ80 OEM Shock Cup Washer 2 ea 102-28K $4.65
FJ60 Spark Plug Wires OEM Cord Set, Coil & Spark 90919-21325 $63.82
FJ60 Spark Plug Wires Toyota LiveWires C9079BL $60.00
FJ60 Starter OEM Reduction Starter 6/82 - 8/92 020-020E $70.00
FJ60 Steering Wheel Used $125.00
FJ60 FJ62 Rear Anti-Sway Bar Extensions Extended Links 48802-62RRKIT $35.00
FJ60 FJ62 Front Anti-Sway Bar Extensions Extended Links 595-164 $35.00
FJ60 Throttle Linkage Used $50.00
FJ60 U Bolts Set of 4 - Rear Axle 8/80 - 1/90 FJ40 BJ40 FJ60 FJ62 Extended Length UBOLTS-4ea-8/80-90-Rear $49.71
FJ60 US Intake Air Cleaner Assembly 2F 012-20L-U $85.00
FJ60 Valve Cover Used $60.00
FJ60 Water Temp Sender 549-101 / 182-12C $30.00
FJ60 Window Crank Handle Used $15.00
FJ60 Windshield Wiper Arm Cover 85192-14010 $15.24
FJ60 Wiper Control Relay 85940-90A10 $20.00
FJ60 XYZ Vacum Control Valve VCV 90925-03192 $25.00
Tanks Inc Adjustable Fuel Pressure Regulator with Gauge AFPR1 $85.00
Advance Adapter 2.5" GM LS Gen III/IV Manifold Collector Rings and Gaskets 717514 $51.89
Install Bay IB200 200 amp Battery Isolator and Relay Solenoid IB200 $42.99
K&N Performance Wrench-Off Oil Filter HP-3001 $9.98
JMY Battery Switch Isolator Disconnect Cut On OFF Kill Marine N/A $9.99
Brian Tooley Racing .560" LS6 Beehive Valve Springs Set 16 SP011-16 $69.99
LS Coil Pack Mounts Used $20.00
LS MAF Sensor Used $25.00
LS Throttle Body Used $25.00
LS Valve Covers Used $40.00
Brian Tooley Racing LS Hat Valve Seals 2001-up VS LS HAT $36.00
Perko Heavy Duty Battery Selector Switch with Alternator Field Disconnect 8603DP $157.99
Novak Adapt EGR Block-Off Plug LS1 Vortec 12558346-K $32.10
Novak Adapt Manifold Vacuum Brake Booster Adapter Fitting LS1 G3VP $19.11
Optima Batteries D35 YellowTop Dual Purpose Battery 8040-218 $243.89
CE Smith Trailer Roller Shaft with Cap Nuts 10705A $11.41
Spectre Performance 4" 40 Degree Aluminum Elbow 9740 $29.99
Spectre Performance 4" 35 Degree Aluminum Elbow 9739 $29.99
Spectre Performance 4" Polished Low Profile Single Plenum 4" Inlet 98499 $105.37
Spectre Performance 4" Filter Support Bracket 9702 $29.99
Trailer Wiring Hopkins 48435 6 Pole Round Vehicle Connector 48435 $9.38
Trailer Wiring Hopkins 48445 6 Pole Round Vehicle Connector 48445 $7.01
WIX Fuel Filter 33204 $6.80
I will take the fj60 hand throttle and choke cable.
