1985 2f manifold nuts and bolts
This is not the case. The two studs are there to 'Hang' the assembly, then it lines up the rest of the holes. I tried the all bolts before with a forum vendor and it was a pita and we went back to studs. All studs is no good, also.
Toyota did it right
I've got all bolts now. For 10 years. Reflex gasket and tight bolts and it's all good.
However, as I'm replacing the HG now, I've discovered some bolts with questionable threads, so I wan to replace them.
the bolts I have are 17mm head and resemble the 14mm.....but forget where I found the cross reference years ago.
is there a current P/N for the 3 down pipe studs and nuts?
I can find the nuts, but only see half a P/N for the studs (17152)
yea...saw that. not gonna order from there.
I see SOR has them, but was looking for other vendors as well
(or what thread size they are, maybe a 'universal kit' could work)
thanks @OhioFJ
I might have the parts bag from my order. I’ll check
