Can someone please point me to where the slave cylinder is on a 1984 2F? I cannot find it and the FSM (found online) does not specifies where the slave cylinder is located in the engine bay.
The clutch failed on me on the first day after buying my first FJ. I drove from the PO's place back home for about 120 mi. and close to home I notice some rubber banding action on the clutch during city driving. Sluggish and very loose feeling on the pedal. Sure enough about 1.5 blocks from the house the clutch wouldn't engage.
Not knowing much about the clutch, the google machine pointed me to the clutch master cylinder. And I noticed right away that the reservoir was empty. It was not empty a couple of days prior when I did the initial inspection on the rig. So first project.. look for the leak.
In the meantime, I did take the master cylinder out and took out the reservoir as I noticed some gunk and black paste looking residue in it, so I suspected clogged piston/lines. Is the original master cylinder so it needed some cleaning. It is clean and ready to go back in, piston has nice and smooth action when pressed so I am hoping this should do it. However, I need to know where the slave is located so I can bleed the air outta the lines once I install the master cylinder back up.
Thank you.
Thank you.
