- Location
- United States
Original late model 84 fj45 ute built by an aussie diesel mechanic. It has a 1hz diesel shortblock with a factory 1hdt 12 v head and turbo setup running around 15psi,h55 5 spd,4 wheel disc brakes with a factory hj75 rear disc full float rear with built in e brake. Hj60 power steering gear box conversion using all factory ps components. Thomas pto winch,factory ac(needs compressor hoses) dual battery set up with aux battery in rear tool box. Autometer oil,temp,and volt gauges.CD player,factory floormat,snorkel,33 inch tires on steel wheels,extended greasable shackles,bullbar,arb extreme sport idf driving lights. This truck was built to be used and driven, the truck is virtually rust free,floors,cab, bed has no rust through anywhere,frame is solid,no rust. The truck was originally a ute with a tray,the po put a styleside bed on it and it was painted by the po,so it is not the best paint job,the cab shows some over spray here and there,so cosmetically its not perfect but overall looks good. The wiring needs to be cleaned up, but everything is functioning. This truck comes with the dot/epa import paperwork and a bill of sale. Aussie trucks dont have a title,please check with your state to make sure it can be titled. It is the holy grail of fj45 pickups,and would be near impossible to build here in the states. Please be serious and have cash,asking 30k. I dont have time to answer a bunch of questions, if you are serious give me a call @ 650 796 1213 and I will be happy to go over the truck in detail. thanks Located in the bay area, california 94074
