For Sale 1983 OM617 - 200k miles, runs excellent w/4x4Labs adapter to H41/H42/H55 - Tentatively SOLD.
Durham, NC
Selling an OM617 diesel with 4x4labs adapter and machined flywheel to bolt the diesel to the H41/H42/H55 transmissions via the toyota bellhousing of your choice.
Asking $1250 for the whole package. OM617 is a 1983 with 200k miles. Only had valve adjustment done immediately before being pulled because it runs so well, it didn't need anything else! Pulled myself from the vehicle a little over two years ago and has been sitting since.
OM617 complete from valve cover down to the oil pan. No radiator, but all engine accessories are included. The motor comes with the 4x4Labs adapter kit which is $750 new. The flywheel has been sitting on a bench so it will need the surface rust taken off of it, $35 at a machine shop:
Toyota Landcruiser H Series Transmission Adapter
I've got a used Toyota clutch as well as a 3F bellhousing that will go with the motor and adapter, but it'll be up to you whether or not you want to use it.
I did not do a compression test nor do I have a video of it running. I personally heard the motor run and it was in good condition with little to no blowby, so I did not think a compression test was necessary at the time I pulled it. A video was not taken because I was planning on using it in one of my projects.
Right now the motor is sitting on the floor in my garage. I've come to the realization that the project I want to do is too far off and I could use the $$ from this motor to repair Moonshine.
