I own, (since new) a 1982 Pickup and just replaced the timing cover and set. All is well and have good oil pressure except when it sits for a few hours it takes a while for the oil pressure to build. I think it is a priming issue but it didn't happen until I did the repair. Did I leave something out? There is a spring and plunger under the 22 mm vertical bolt and that is installed correctly as far as I know. Could it be the copper washer not sealing? Anything you can tell me will be a great help! Thanks!
